I ran into my first issue with the skis I just bought a few weeks ago. My 2000 GSX RFI won't start. I have began my troubleshooting and I am thinking it is the starter that is the cause. I was getting the clicks at one point when trying to start it, but now I am getting like a short noise, not 100% sure how to explain it. I guess the closest word to it would be a grinding noise. Its sort of like errrrrrrr. After that the dash goes out. I put a trickle charger on the battery overnight and still the same thing. I tested the battery and I am getting 12v out of the battery. I tried shorting the Starter solenoid, same noise. Checked the voltage at the solenoid and getting 12v there as well. Seems to me like the starter must be bad at this point. Any thoughts? Prior to it not starting it was running fine all weekend. We came in to switch some kids out for rides and would not start. Also if the starter is at fault ok to get one of these?
or should I spend the extra money for this?
I would like to keep the cost as less as I can as with just buying these and everything that has come with them has drained my account a little, but I do understand you get what you pay for sometimes.
Let me know what you think. I did start taking things apart to remove the starter last night and was going to see if I could troubleshoot the starter itself tonight. Also anything else I should try?
