I forgot to mention that the plugs were wet with gas. dried them several times and blew out cylinders. Ultimately it did start after sitting another hour and planed off and got me back to the ramp, but still could tell it was missing at lower rpms.
Check your compression....use a good guage, double check with another guage just to be sure...NO Harbor Freight guages either (JUNK). 150 psi is ideal (I believe) but both cylinders should be VERY close to each other, only a few psi OFF is ok. A wide variance indicates troubles.
Service/REBUILD the carb with a genuine MIKUNI KIT (you should have a Mikuni BN-40i carb in there and the manual says its a 115 gram spring (which may NOT be part of the Mikuni kit, so you may need to get that separately), follow the carb sticky post (top of the forum)...my bet is you will see a world of difference. Also, IF still installed....replace ALL old grey fuel lines with 1/4" black auto fuel hose, replace fuel selector switch (not just cleaning), fuel filter O-ring gasket too.....make sure the fuel tank is clean and new fresh fuel is being used.
You may also consider new needle and seat [2.0 needle & seat] which are also NOT part of the carb rebuild kit, purchase separately.
Might also want to check/verify battery and rectifier operability.....with ski running at idle (3000 on trailer/ 1500 on water) see what the battery voltage is at...should be greater than 12.7 as high as 13 + volts....smooth, not bouncing all over the meter......if its not greater than 12.7...probably a bad rectifier (or the magneto, but rule out the rectifier first).
The ski is 20 years old, she is going to have issues.
