2000 RFI runs on 1 cylinder
oppeau
For the last 5 years once a year I would have to replace a plug that would not fire, it would be wet when I removed it. I could tell because of the power loss it was another bad plug. This year something changed. When I first take off it may run fine for about 500 feet then I get the same feeling I use to with a bad plug like its only running on 1 cylinder. I have replaced both plugs several times and still have the low power issue. Sometime the other cylinder will "kick in" and it runs great for another 500 feet or so. It sure seems like I'm losing spark to a cylinder, any ideas on where to start. I do have mechanic skills.
Thank you
John
Buy a spark plug checker for $5.00 at Auto Zone. You can ride the ski with the seat off to do some checks. You could also have a compression issue.
