2000 GTX Issues Please help !
allmotorek24
Ok so i picked up a 2000 sea doo gtx millenuim edition a few weeks ago and it has 110 hrs on it. The previous owner provided me with a full service that was done on 5/8/09 about 3 months ago reciept that came to 726.00. The sead doo dealer did the following:
R&R Carbs and fuel system as needed
Compression test 140/135
Adjusted ,lubed the driveline, Inspected jet pump and impeller
Changed jet pump oil , Replaced battery, Verified fuel system
Replaced main fuel filter , internal fuel filters, diaphrams , needle and seats.
Cleaned the accelerator pump , cleaned and inspected rave valves
Adjusted carb settings
Drained old fuel
test run the engine on the flush hose
New Ngk plugs
new mikuni diaphrams ass
2.0 needle and seat
fresh gas
Problems are that i have a slight amount of oil in thr rear on the hull and i tried to clean it up and it comes back ??
Fuel guage doesnt work blinks red and says low fuel even with a full tank ?
check the res bottle, make sure the hoses arent cracked and if anything, just came across ski, that the fitting for the return line, was cracked at base of the casing.
Thanks for the advice i will look into that today on my oil issue , i ended up buying a new baffle/sending unit for the fuel tank with tax came to 180 and installed that yesterday was a breeze,fuel guage works perfect now!
