RockyQuagmire
I have a SeaDoo 2000 GTi. No more than 150 hours. The engine at about half throttle misses and cuts out. Will not run any faster than 1/2 throttle. Changed spark plugs. Took off carb, apart and cleaned the screen. The rest looked good. Took squirt bottle with gas and sprayed into carb while in water on ramp and still missed bad. OK until half throttle. If you hook a hose to the hose inlet out of the water while running it eventually chokes out. Compression for both cylinders is 152. Voltage at battery when running is 14.
Any help appreciated.
Thanks in advance.
Rocky
Thanks in advance.
Rocky
