Jmkaufman84
I need help!! I recently purchased a 2000 Challenger with a Mercury 240 EFI and it wont start. So far the ECU has been swapped, new High pressure fuel pump, new plugs, crank trigger, fresh oil and fuel. The boat will not start and run in or out of the water, I have verified fuel pressure and spark.
The strange part of this whole situation is that if I move the crank trigger linkage it will actuate the fuel pump briefly, if I do this repeatedly and then try and start the boat it will start and sometimes run. I have had the boat idling on the hose for 10-15 minutes, once I shut it off and then back on it would restart multiple times but eventually go back to cranking with no start. I am not sure where to go from here, any input would be greatly appreciated.
-Josh K
-Josh K
