hellz_wings
I have a 1998 Seadoo Speedster (with twin 787's). I've had this gas (91 octane, non ethanol) in the boat since August 2019 now, and the tank is about half full. We put a marine fuel stabilizer in the gas tank with the fuel back in August 2019 before storing it then and it has not run since (I'm in the process of re-doing engines, carbs, new fuel pump, etc.) I am bringing the boat back into storage as is, with the work unfinished and will finish it all up in spring *(April/May) of next year.. My question is, what should I do with the fuel in there now? Can I just fill it up to the top with more 91 octane non-ethanol fuel and put more fuel stabilizer in there and should I do this NOW or leave it as is and do it in the spring time, or do I need to drain it NOW and put brand new fuel and stabilizer? I'd rather not have to drain it now as time is limited at the moment and I need to bring it Friday to storage, but will do it if I absolutely need to (ie: remove the fuel baffle again and siphon it out with a manual siphon pump that I have, hopefully the hose is long enough to get it all out!). Thanks in advance for the help!!
