drew66
In the process of refreshing a 1998 gtx rfi I ran into the 2pc oil tank split at the seam issue. During my research reading about split tanks on many forums there is also apparently a leaky grommet issue with the new upper and lower grommets. As the oil system is a critical part of the ski, I decided to weld the tank solid and add a few enhancements to help hold down the upper sensor and lower feed fittings. I can imagine how the new grommets would leak with heavy oil filled hoses hooked to them and constantly bouncing around.
Any thoughts or ideas for improvement?
