mykd99
Hi, I have a 1999 XP Ltd. I've only had this ski for 2 weeks now and am new to these machines. I've only ridden this machine 3 times. When I bought it, it started right up, out of the water. Took it home, went to ride a week later and it wouldn't start out of water. Would just turn over, never popped. When I got home, cranked it till the battery died. I played around with the fuel shut off and got it to run, but not sure if that was the problem. Took it out another day and it started right up out of water, dropped it in the water and ran perfect for about an hour. Was riding in the channel pretty much on idle and it shut off, wouldn't start back up. Pulled plugs, were wet, turned motor over to get extra gas out of cylinders. Waited about 10 mins and tried starting again. Was turning over and popping, but not starting. Finally got a good pop and hit the gas and it managed to start and run fine the rest of the day (about 2 more hours). But I didn't let it idle after that. Took it out another time, and it did the same thing, would run fine, but when I shut it off or let it idle for a long time, it will not start back up. I have to wait about 10 mins. then try starting it, and then it seems to work.
At this point I am assuming it has something to do with spark. I am going to get new plugs today (and spare ones), and see if that helps. I was thinking it could also be fuel, but like I said, the plugs were wet.
Thank you in advance!
Mike
Mike
