pwgsx
I usually remove each acc pump line to each carb and spray some carb cleaner in each hole to see if its spraying into the carb. You can also manually press the pump in by hand right after you remove the carbs from the ski and there should be enough gas still in the pump to see if its making its way into each carb.
