interrider1
Good morning, I have a couple of ?'s.
I replaced the stator, blendix drive, starter. The ski comes on with two beeps, battery, brand new. Turns over fine (fast) has no spark. The computer comes on board, with modes, clock, and so on.. Than LED goes blank.. The clock is out.
Does the computer pickup the stator, it doesn't have to be programmed. Correct.
Next what could be going on. Ground wrong, bad stator, crank sensor bad. Protrusion hole lined up with long bar on flywheel (after bar) woodruff key fine. I'm really getting frustrated. fuses fine double check. spark plug tester shows nothing. I don't know where to go from here, the ski always ran prefect for her.
i've pulled the motor twice, double check work inside flywheel. i really need some expert advice.
Once again Thanks for these Rooms.
