1999 sea doo xp not starting
wtoll
I replaced all of the gray fuel lines on my 1999 sea doo 951, than I cleaned out the carbs. Started her up and she was running graet so I put her in the water every thing was going good no bogging or any thing for 10 minutes than all of a sudden the ski starts to bog down so I bring it back go the dock to cool it down than see what is wrong. I go to start it back up and nothing and now it's not starting and all. any suggestions on what I can do, has this happens to anyone else. Thank you.
Sounds like either you lost the engine... or something clogged up the carbs. OR... the fuel valve is faulty.
If this was my ski... I would check the compression... then try to suck fuel up the hose where it connects to the carbs.
