1999 gtx missing oil with fuel
There really isn't any need to, if the oil injector pump is working correctly. If you do add oil to the fuel tank it might foul spark plugs.
Karl
Use Stabil as the additive of choice. Its good for the tank & lines, and carb
diaphrams. I Highly recommend! It can extend gasoline life 10 fold.
:agree: for winter storage, but for everyday use it shouldn't be needed.
Karl
star-tron is a better all the time use product
it helps with the ethanol fuel problems
as for oil in the fuel, yeah you could do it, no more than a 50-1 mix
this is common practice on new engines, but not needed on a proper engine
but just check your pump adjustment, maybe advance it a bit if you want
carry those extra plugs tho, and a wrench
spark plugs are cheaper than top ends
mud
Karl
Stabil also breaks down moisture molecules. A water droplet in a carb
can prevent gas from entering, THUS: A lean condition ruins a perfectly
good Seadoo.
I HIGHLY recommend this product
