Hello,
I am new to the world of PWC, at least as an owner. This 1999 Sea Doo GTX Limited was given to me about 4 months ago and ran fine... until last week.
Symptoms:
Motor (951cc) idles fine and doesn't seem to miss.
At part throttle, the motor powers the craft fine, up to 35-40 mph.
Giving it more throttle (close to WOT) the engine will gain RPM up to 5600 then "Bogg" down to 4500, then back up to 5600 and down again. This bogging and lurching happens rhythmically at about 1 second intervals. This problem came on in a matter of hours, getting steadily worse but has since plateaued.
No trouble codes or beeps are noted from the computer.
Found a broken stud in the bottom of the craft, all head studs are accounted for and I cannot find where it came from.
What I've tried thus far
Changed the spark plugs - no improvement
Cleaned the RAVE valves as per forum instruction (Thanks to the author!) - no improvement
RE-assembled the water pressure regulator (the metal band had come un-screwed) - no improvement
Any advice would be appreciated at this point as I am sort of baffled. I am new to PWC but not new to two stroke motors, or mechanics in general, so nothing is out of reach.
Thank you,
Dan
Symptoms:
Thank you,
Dan
