chazdo2
Help somebody more knowledgeable than I. Here is the scenerio: New fuel lines, cleaned fuel switch, removed fuel baffle no problem their, pressure tested entire fuel system per shop manual, cleaned all filters small carb ones too, cleaned carbs twice, ( pop off pressure is 5 psi higher than manual suggests ) 135 psi compression, repaired exaust water leak that started problem to begin with putting water in intake box. Cleaned and dried it out. Just putts about 5 mph I let in run full throttle for a minute ( only goes 5 mph at full throttle sounds like its breaking up sputtering) then pull plugs. Both are black/brown but not wet. tried new plugs same thing I dont have a clue what else to do. It also has a new pump and impeller. Could there still be water in the engine? Plugs dont seem to be fowling though they are dry when pulled.
