Okay, I have a 1999 Sea Doo GSX Rfi that has been freshly rebuilt (about 10 hrs.). I was out riding it the other day and it all of a sudden started missing and lost all power. I got it to crank, but it wouldn't turn over 3500 rpm, so it was a long ride home.
I got it out of the water and did a quick once over and saw nothing obvious. I put new plugs in it, checked the compression (155 & 160 #), checked for an exhaust leak (hoping it was just suffocating itself) but found nothing. I tryed checking out a few other possibilities, but to no avail. I keep coming back to an exhaust issue. I can get it to clean up and run with the seat off, but with the seat on, or after some sharp turns it dies and then is a pain to get restarted and keep running. I pulled the rubber hose from the "discharge" tube on the starboard side and off the big black round "doo-hickie" that looks like a muffler. After removing the hose and cranking it back up, the "doo-hickie" was full of water...is this normal? Is this my problem, and if so, what is letting water get into it, and why doesn't it have some sort of drain?
Thanks,
E
Thanks,
E
