I don't know what a 471 gauge is, all I know is all the wiring schematics I've looked at, including the one for either a 99' GSX RFI or Limited, and my 2 skis, a 97' GTX and a 96' GSX, the info gauges have a red/pur and a pur wire that both need to connect to 12 volts. Once you do this on the bench test, jumping these wires, along with a blk negative, it'll at least light up 12:00 on the display.
If you've got it apart or disassembled, double check the large connector that joins the LCD and main board for corrosion, sometimes cleaning/lubricating it helps. When you say burned out, do you mean the display looked cooked? Mine was black and badly burnt, I scrapped the old off and applied the new film, it looks like new now.
