so i bought a project challenger.
guy i bought it from said it ran great (in salt water) just needed maintenance
both engines have 150 psi in each cylinder.
first time i turned them on seemed as they were in WIDE OPEN THROTTLE
bought new carbs for each engine
first engine idled a lot better, the other engine did the same (WOT)
i swapped carbs again and they were not as bad.. but still seemed as if they were reving too much for idle.
i took it to the water... (lots of smoke but it kinda went away after a while)
loud beep which i would turn off by pressing the bottom right yellow button
the small black pressure valve on one of the engine was leaking a little bit of water from the bottom
i got the boat to do 12mph full throttle.
i did not really pay attention to the rpm or anything else other than my boat sinking (very new to boats)
I checked impellers, they move freely but WEAR RINGS are gone.. completely dried out.. could this be making my boat run like crap and top out at 12mph?
what else should i look into?
