Out on the lake yesterday, ran into a couple problems.
1.) There was a bass tournament so I had to sit in the water and wait to get out for about 30 mins or more. All of a sudden I noticed I was takin on alot of water in the foot wells and it was kinda sinkin me. So I started it up and took off before I sank. I put it on the trailer asap opened the back hatch up and it was almost full or water. Idk if my bilge quit workin or what. When I got home I checked it out, idk how its supposed to work when its not running but when I put the key on the bilge will run for couples secs and turn off. Its fully auto bilge and has a float. If the float is up shouldnt it run non stop? I poured some water in it to see if it'd pump it and it did, so idk why it filled with water when I was sitting. I did find a small perfectly round hole right in the middle of the bottom. There is like a small depression right before the pick up, and there is a hole right in the middle. Is this supposed to be there? If not its probably why it almost sank.
2.) Every now and then I'll just be going along and it will die in the water. It'll start right back up and just die again. I wiggle the key around and fixes it. This just bad connection and/or worn out key?
