1998 xp limited with strange starter issue
wakesk8fool
I have been dealing with this problem for a very long time. My 98 xp 951 has a very strange starter issue. When i try to start it the starter will sometimes engage perfectly but other times it will not start at all and then when i finally get it to roll the starter kicks in and out quickly. Now the motor does eventually start and sometimes starts immediately. The problem is that i have already sacrificed a bendix gear due to this problem and can afford to do another in. I am very handy with this ski as i have already had it apart several times. I have spliced in a new switch and that was not the issue. i have checked all grounds as best as i can. i have found that the hot wire to the solenoid from the mpem has a fluctuating current which causes the solenoid to disengage while rolling over and than engage again quickly. Any help i greatly appreciated and i already fear it is the mpem due to the internal relay but was hoping somebody could shed some light on other possible issues.
ive repaired a few skis with the same problem. check the female connectors at the mpem harness which corresponds to the starting circuit. be careful when working on the harness as it can easily be damaged.
same problom
im 15 an been workin on my tigershark an yamaha with no probloms butt for some reason i have the same problome with my xp limited 951 an cant figure it outt i cant even find the starter i could use som pointers and a sorce of direction it would really help me out thanks
