I bought a used XP LTD Its over heating. Trying to Check water flow. The print i have from manual is so wrong from what i have. When using garden hose.(long pipe on back.) Water goes to the bottom of Exhaust Chamber. In picture it goes to the top of the engine. If the print is right then why does it say that long pipe goes to the top of the engine and say it is the (Engine water return?). The arrows i added is the way water moves thru the system with water on hose. (long Pipe)Running. Also at the Regulator valve why does water push thru on both sides of the regulater? Is that Right.
THE SUPER BIG QUESTION. Where does the water come in from the lake water. How and where does water enter the system from the Pump? I dont see it. Where can it be blocked at?
