schulte
I have tried to jump the solenoid with a screw driver and it did attempt to fire right away. I can hit the start button and the dash turns on and when i hit it 5 times it does a short beep and then a long beep. I put the key on and the dash turns on and does 2 short beeps, when i hit the start button it does nothing no beeps no starting but after 10 seconds it gives a long beep. Even if i put the key on and it gives the 2 beeps and i never hit the start button after 10 seconds it still gives the long beep.The waverunner did sit with a dead battery for 2 years , wondering if the long beep means its not recognizing the key and i might need to have it programmed. Not sure if the post has issues any advice is appreciated.
