whatsajetski
Memorial day weekend I took this ski out for more or less testing purposes. I have been having problem with the key connecting with the DESS post that I thought I had solved. I had read to wash both with soapy water and it will help restore the contacts, did this and it didn't help, then put a small dab of liquid copper lubricant (kinda like dielectric grease but not as fluid). This fixed my key problem, or at least I thought. We got out on the water and it fired right up and ran pretty good. My wife just hovered around the dock/launch while I parked the truck. I got on started it back up and she was running good. Got out of the no-wake zone and gave it a little throttle slowly, it got up to speed pretty good so I proceeded to acutally ride it going back and forth and giving it throttle and it was running great! Turned around to stay by the dock cause we were still "testing" it. On the way back to the dock the whole ski just shut off. I pull the key and reconnect it, nothing. we stop by the launch where I can stand in the water and work on it. I disconnect the battery and reconnect, nothing. Disconnect and wait 30 seconds reconnect, and I get one beep. Try the key nothing. Disconnect and try and wait longer (about 5 mins) try again nothing. So we loaded up and went home. Once home I voltage test the battery, 12 volts even. I check both the 5amp and 15amp fuse neither are blown. So now I'm stuck. I'm thinking the DESS post might have gone bad? How do i go about testing it to see if that's the issue?
Sorry for the long post just wanting to give as much info as possible.
