hoodmekanik
i have been working on this boat for some time... i have changed 4 spark plugs BR8ES many times ... new coil packs... new spark plug wires... new rave diaphrams and gaskets... cleaned rave slots... new fuel filters... 4 mikuni rebuilt kits... carb dipped all 4 carbs... blew compressed air through all the holes and passages... everything comes out clear... and all 4 cylinders have 150psi
my problem is now that both engines are idling perfect in the water at 1500 rpm... when i throttle up both engines at the same time.... the port side engine runs great, throttle response is quick but the starboard engine revs up slowly to about 3k and than pegs to 7k rpm, now both engines are pegs at 7k rpm for about 15 secs and than the starboard engine loses power to 5k rpm and stays there... now if i throttle down than open throttle again both engines peg to 7k rpm...
ive also slowly throttled up to wot each motor and they will stay at 7k revlimit for 30+ secs with no problems
now when the starboard engine drops rpms at wot i drop the throttle on the portside engine and the starboard engine starts to increase rpms.... so i can throttle down the portside engine and have both engines run at max 6k rpm and have consistent power...
any ideas
my carb settings are 1.5 low setting high setting 1/8 turn
any ideas
