Hi guys. I’ve had several different threads dealing with this boat but I’m gonna sum everything up and hopefully this will be the last time!
First of all, this is what we’ve done to it.
Okay so I’m going to start on a couple weeks ago when we took it to the lake. The boat was running awesome almost the whole time, both engines running at 7k rpms like they should. Until the way back to the boat ramp. It started dying and wouldn’t stay running for very long.
Just decided to bring it back home and take a look.
Got it home and nothing seemed wrong, we took the carbs apart and checked everything. Looked alright. Fine tuned the pop off pressure and re installed.
Next weekend. We took it out on the water to test it and different symptoms occurred. First, the boat ran fine at 7k rpms for maybe a minute or two until the drivers side engine died (like a loss of electrical power) Started it back up and then neither engine would go above 5k rpms.
Ran around for a little bit and then the drivers side died and wouldn’t go above 3k rpms.
Headed back to the boat ramp and then the drivers side kept dying/wouldn’t stay running for longer than 5 seconds.
We limped our way back onto the trailer.
The whole day we were testing to see if we was running lean by pulling the choke, just died every time- so it wasnt running lean. Also, throughout the day there was intermittent dying on the drivers side-like loss of power.
(I have videos of all of these symptoms except it running at 7k)
Got it back home and did some research, replaced all 4 spark plugs and trimmed all the wires down.
Decided to take it out again and see what’s up.
First, boat ran good like it usually does- 7k rpms.
Next, the drivers side engine died like a loss of power. Then neither engine would go above 5k.
We drove around for a decent amount and they stayed at about 5k unless we hit a turn or wake just perfect then maybe one engine would fire up and run 7k but not every time.
We have been and I still am thinking this is an electrical issue. The reason I believe so is because it runs good until the engine dies-like a loss of electrical power. And then it just won’t run above 5k rpms again.
But, when we did hit a wake or turn just right it would go above- which wouldn’t be electrical I would think. But who knows.
Any help is greatly appreciated. Sorry this thread is so long! Lol
Thanks!
- Cleaned and replaced all carburetor parts with Mikuni oem. As well as 4 new 80 gram arm springs. Set the pop off pressure as well.
- All fuel lines and oil lines were not the originals and looked very open.
- Cleaned all 4 rave valves
- Replaced all spark plugs and trimmed the wires.
- Brand new battery
- Replaced one of the solenoids that went bad. Both are working and in good condition now.
Thanks!
