1997 xp just cranking
Seadoo-2021
Guys i recently hydrolocked my seadoo. Got it going........ plenty of fog oil and a good blast out all was well.
I took it to a local river and launched it off a jetty
then...... on my putting to a local stretch
full throttle for 20 mins back and too back and too it ran perfectly perfectly and I fell off.........the craft didn't tip or flip etc. Just scooted me off the back.
I took it to the side of the launch pad checked fuses in mpem and removed plugs I was getting intermittent sparking. I'm getting none. I removed all the electrical plugs from the mpem sprayed electrical cleaner on them ensured all was clean and dry.
The box with the plug solenoid in cleaned and sprayed all the plugs no spark still?
I get 2 beeps? Could the coil pack be wet? Mpem shot?
Any help would be appreciated .
K...easy moves first,,,check your battery terminals,,,are they tight?..is the battery at 12.6?..load test the battery,,,check the E box,,,water,,,corrosion,,,etc,,,mpems don,t just quit on a sinking,,no spark,,,check the front plug,,,leads to the pickup/trigger coil,,,okay...go into the Ebox,,,pull the white lead to the coil,,,put a test loght on it grounded of course,,,try to start it,..and see if the light pulses...if yes your problem is in the box,,or coil,,,unlikely...if not,,,your problem is up stream at the trigger,,,or..mpem...(unlikely)
Will report back today.
Will try these things. Thankyou ;)
I have an aftermarket arieltek mpem..does anyone know how to wire it up and make it run. Says it doesn't require dess key programming to work.
