GrupaNation
Check out the link in my signature block for the history on this machine.
So I replaced all the fuel lines, new fuel selector, new fuel filter/ O-ring, cleaned and rebuilt the carburetors with the OSD Mikuni kit, cleaned the check valves on the fuel breather, and put a new check valve on the accelerator pump. Spark plugs are basically brand new, and compression read 135PSI in both cylinders. Why will it not start up?
The only way we can get it to start is pouring some gas down the carbs. then it will run but it doesnt seem to be pulling any gas from the carbs.
The accelerator pump is just pumping air out the nozzle, it doesnt seem to fill up with gas.
