I picked up this 1997 Seadoo SPX over summer, it didn't run when I bought it. Wouldn't crank changed the battery and still had nothing so I figured id switch the computer from the 96 xp that I bought recently that needs rebuilt and now it turns over and everything checks out good compression (160psi each cylinder) and spark. I am in the middle rebuilding the carbs and removing the paint and rubber coating they covered over the old traction mat holes. After that I will be wet sanding and buffing the whole hull due to it starting to yellow, I have already removed all of the decals from the top part of the hull.
Plans for the ski:
-Wet sand and buff
-New traction mats
-Jettrim seat cover with hump seat
-Beachouse or work sponsons
-extended rear tabs only the sides
-umi steering with bars and finger throttle
As of right now going to be keeping the engine stock and only doing the handling mods for now, next winter I plan on striping the hull down and painting it when I start to do performance parts
Also started a build series on youtube subscribe if you want to keep updated I will post on here and have videos on there with updates
Plans for the ski:
-Wet sand and buff
-New traction mats
