Both engines bogged down at approx 3200 rpms, max speed about 15 mph.
Per Timmyboy76/Dr. Honda:
1. The Neutral switch tested good.
2. Adjusted both carbs to 1 1/4 (low) 0 (high), saw no change.
However, while testing the boat in the water I inadvertantly got the engines to run correctly at higher RPM by having passenger open the Engine compartment door to take a look inside. When engine compt door is closed, the problems re-occur. Verified this several times. Air flow or temp problem
Appreciate any insight.
