staceyrides
My port engine has failed and will either need to be rebuilt or replaced according to an experienced mechanic; he thinks the crank bearings are gone.
The engine is the Rotax 717 and he suggested buying a short block rather than rebuilding the engine.
I have only had the boat three weeks and had noticed that engine losing power briefly from time to time. Having never owned a jet boat/ski, I have little knowledge about how these work or what to listen/look for. I believe I was having some cavitation issues on the port drive and was wondering if that could have contributed to the engine failure? I would make sure on acceleration not to let the rpm get too high on that engine so I would not break anything prior to having the cavitation issue addressed. Obviously, it didn't work.
Would a cavitation issue cause a cooling issue on the engine?
When I spoke with that mechanic, he said the engine had a heat sensor on it which will cut power to prevent overheating. Is the cooling intake located in the pump? If so, would cavitation cause the engine not to get enough water into the pickup. Would the bearing failure most likely be related to a cooling or lubrication issue or both. If so, repairing the engine w/out addressing the possible root cause would just be a waste of money.
My next question is should I have this engine rebuilt or purchase a short block? If so, who has the best short block for the money? This is going to be an expensive repair, but I want to do it right w/out breaking the bank.
