fastboatman29212
Thanks in advance for any advice.
1997 Sea-Doo Speedster. Twin Rotax engines. Planes fine once I get it up on plane.
Problem: Right engine will die if I try to accelerate. That is unless I slowly advance left throttle to 3000 and then sneak up the throttle on the right, then sometimes it will throttle up too and off I go, but it usually dies.
The Bad: This problem existed before I took it to the dealer, so they didn't cause it. But they didn't fix it like they were supposed to either. Dealer serviced it last spring for this exact same problem. Dealer rebuilt the carbs. Big waste of money 'cause they said it was solved but wasn't and they wouldn't make it right.
The Good: Both engines start easily and immediately. Both engines idle fine. She'll do 55 - 60 WOT.
I'm thinkin there may be a plugged jet or mixture screw set wrong. Where should I start looking first?
