Caseywilder
First off thank for any help i receive. I purchased a 1997 speedster 3 weeks ago. Been using it pretty much daily. Running strong. No Issues. Yesterday It would not start. No beeps when I put the key fob on. I took the battery out and got it charged and replaced it. Now I am getting beeps. I get two beeps when I place my fob on. When I hit the start button I get 4 beeps. It is 100% in neutral. I took the neutral switch out and presses it myself. Same issue. I used a wire to connect the contact where the switch plugs in. Same issue. Whats my next step? Could it be a fuse or maybe a wire was pulled out at the fuse box? Is there a way to jump the neutral wire to see if the switch is the issue? When I followed the direction doing the 5 pushes of the start button test I get the normal one short and one long beep like everything is fine. Please Help!
