Hi everyone. Long time listener, first time caller.
I've been working on a 1997 Seadoo GTI that was in pretty good shape overall, just hadn't ran in a while. After fixing some wiring issues that a dumb*** mechanic "fixed," I finally got it started for the first time in 2 years and let it run on the hose for about 30 minutes. I shut it off and then decided id take the carb off to clean bc i know it has probably never been done. After taking it off, i find that it is cracked at the top by the choke. I order a new one throw it on today. I had also replaced the fuel lines so i filled up that filter right by the fuel selector and tried to start. No luck. I spray some starting fluid down the carb and it runs off that for a couple seconds and dies. repeat a couple more times hoping that eventually the fuel pump will start sucking fuel through the lines. Then i hear a weird noise. I try to start again and I hear this horrible grinding/whining noise. I take the cylinder head off to see if something somehow went inside the cylinder. The cylinder walls look okay, but that noise is horrible. Ive seen a few other threads where people describe a similar noise. Some people say its the starter (which sometimes only clicks even after new solenoid), some say it ate a bearing, and other say something about the magneto. I posted a video below. Anyone have any clue what this noise is? Thanks in advance.
1997 Seadoo GTI Grinding noise
