87Magnumii
I’ve got a 1997 GTX that I bought last year. Was supposed to be a running ski when I got it but that’s not been the case. It starts easily and idles perfectly both on the trailer and in the water. The issue is under load it only wants to rev to about 4500 RPM, unless you jog the throttle or hit a wave and the pump breaks free, then it will slowly get into the 6500 range but as soon as I let off it’s back to being sluggish.
Both cylinders have good compression. All fuel lines and filters replaced with new. Both carbs rebuilt with OSD back to OEM kits. Pop off pressure is in spec. Ive tried unplugging the rectifier. I’ve tried adjusting the water box valve. Nothing makes it any better. I’m at a loss if anyone has any ideas.
