1997 gsi
Changed the grommet in oil tank. No more leaks! Thanks guys.
Changed oil lines while I was at it. Primed system and oil pump took care of the small lines in about 30 seconds.
Bought an actron compression gauge and got 145psi both sides. Yippppppie!!! Harbor freight setup is garbage.
When I pulled the plug I notice a small amount of moisture on the plugs. Cranked engine with no plugs. No visual moisture. Last time I ran ski was on hose. I turned water on halfway after engine started and turned water off before turning off ski. What would cause a small amount of moisture inside engine ? Water pressure too high ? The engine does run a little rougher with the hose on.
I do live in Houston with very high humidity and now we are in 30's. 30's one day and 70 the next right now.
It's just condensation. Nothing to worry about but that is also why I fog my engines every time they are run.
My blood pressure just dropped to normal! Thanks !!!
145 psi on both jugs. Good strong engine ? Book doesn't call for a psi reading. Weird ! But I read online 150 is good to go ....
Yes. At 145 you are in great shape. 150 is perfect and 120 is time for a rebuild. I would have no concerns at 145.
