Had great fathers day on lake, cruising right along. Stopped for a swim and few beverages. One engine would not start. Removed plugs and turned freely with PTO, about 1/4-1/2 turn that is. In one direction its a solid stop, metal on metal. In the other direction it is bit more gradual of a stop. Read on another thread that a carb bolt had gotten into crank case to cause similar problem. My plan of attack, remove carbs and rotary valve. Hopefully can see what is in crank case and perhaps remove with one of those magnet grabbers. If that doesnt work, I plan to go in from the top by removing heads and cylinders. Anyone have different / better plan of attack?
PS was able to get back with the other engine and even had time to stop again for another swim and few more beverages. It was good day.
