skidooboy3
I just bought a Challenger 1800 and the port side engine engine had been replaced last year. I was looking around under the hood and found a loose wire hanging in the rear of the boat with a small plug and I have no idea what it's supposed to plug into. It comes out of the same loom as the wire that goes to the bilge pump and it has the same kind of plug at the end which is just a two wire oval shaped plug. The two wires on the plug are white with a brown or tan stripe. I traced it up and it follows the bilge wire into the same wiring harnass and goes all the way up to the area behind the steering wheel where all the guages and switches are. It goes into a fuse block board where there is a large wire plug with about twenty wires coming from it. I plan on buying a wiring diagram soon but thought I'd see if anyone knew where it goes just from this description. Thanks.
