Huntz52
I purchased the challenger a few weeks ago knowing it had some engine issues but it was for a really good price. the guy that sold it to me said he had traded his motorcycle for the boat and that he has started it, but I believe he is full of it. Although this is what I have found: Both Engines roll over but won't start. I eventually picked up a spark wire tester and sure enough am not getting any spark. I was messing around and checking to make sure electricity was hitting where it should in the MPEM just by following the wires from the battery and mostly everything was getting power except the ignition coil. I had my wife roll it over a few times while I checked the power at the connections and I wasn't seeing anything. Fuses in MPEM all test good. Is there a better way to test the ignition coil?
Other things that need to be done for overall restoration:
-weedless system- Handle seems to be stuck and grates on bottom are just hanging there. I can see the connecting rod looks rusty and maybe some missing..
-Engine 1 choke line needs to be re-ran
-Bilge Fan needs to be riveted into the correct spot
-Fix gas gauge meter. It appears full of gas when the tank is visibly low
