shattered00
Hello all,
I have finally got one of the 1996 XPs fully assembled. It cranked last weekend without the jet pump on and I did not let it run for long since the driveshaft was slightly loose. I put everything together and the impeller spins freely. The ski will keep trying to crank but does not turn over. The carbs appear to be pulling fuel as there is fuel in the line going from the separator to the carbs. The negative terminal cable gets hot on the end when I disconnect it after trying to start. This is for a newly rebuilt engine that has never run since being rebuilt aside from last weekend. Here is what I have done.
- New spark plugs gapped properly
- New fuel lines
- New fuel selector and fuel separator
- Rebuilt carbs with Mikuni kit
- Bypassed everything and ran the fuel line to the carbs straight to a gas can and still nothing
- Used dielectric grease on all points where a starter cable connects to either the battery terminal or the starter
I attached a video link so that maybe someone can tell what is happening from the audio alone? Using the choke and depressing the throttle slightly did not have any noticeable affect.
Thank you for your help.
- New fuel lines
