Good morning! Looking for some help/info on my white 587 operating temp. (1996 Spi)
After replacing oil tank grommets, all oil lines, bleeding pump, and running tank of premix for safety, did a test run, while checking for any oil leaks, I noticed engine was hot to touch, while running on trailer I noticed air bubbles in two pissers off of head and exhaust, the head line was a little looses and end was stretched, I cut both back, and installed, I also replaced the 1/2” line with the hose t with a straight clear hose, I blew all other lines out with air, they are all flowing,and get a strong flow out of both pissers out back, although water is hot, and as I said, so is motor, the ski is running great, my question is what’s normal operating temp for these, and could I still have a restriction in cooling sleeve even though I’m getting good flow out of pissers. The exhaust pipe itself is not hot, and the new 1/2” clear line does not seem to be full with water, at least at idle, on trailer. if that helps diagnosing.
I don’t want to keep running and do any damage if it is running hot, Appreciate all feedback.. thanks, Mike
