Hi
Last year I bought a 96 speedster for 3K with the understanding that all was good with the boat or I could return it. I took it out and had a problem with one engine overheating. I took it to the shop and explained that I could see water coming out where engine connected to tuned pipe and was only getting a trickle out the back (pea hole) and that a water line burst that connected at the tuned pipe. I asked them to check it all over since I was purchasing boat.
I got boat back and they welded both pipes, they said freeze plugs popped, and they replaced some lines. They did all this work without even checking compression until they called me and I asked what it was.
The one motor was in the high 130's and low 140's and the other motor was in mid 120's and low 130's.
I was able to return boat since it was not as advertised.
I now have the option to buy the boat for $1500 as is. The boat is in good cosmetic condition and I was wondering if the tuned pipe could have been causing the problem with the overheating. I know the compression is not ideal and was wondering if anyone had an opinion if this would be worth the risk at this price point and what it could end up costing if a motor needs replaced.
Thanks
Thanks
