I took my carbs off to clean them in hopes to fix an engine hesitation that i am having. Once the carbs were off I followed my manaul and took the carb apart to clean it. After reading a few threads i realized that Is shouldnt have touched the high speed needle , that it is set from the factory. IS there any guidance one can give on how I should go about setting this needle to the right position.
What i have done thus far is . I originally only took one of the 2 carbs apart a time. So I took the other carb and backed the high speed screw out and counted the rotations. I then used that as a guide to put the other screw back in, but in doing so I wasnt able to complete the number of rotations needed to match the untouched carb. The needle fully tightens before i can reach the number of rotations of the other carb.
