Little background, i just bought this boat, changed pump oil. previouse owener just replaced wear rings, polished props never had boat out. Engines start good and pull hard once on a plane. Bad cavitation problem? Seams to be equil on both engines? i am going to pull pumps tomorrow and check wear rings and reseal pump to seal. what should i look at in threw hull seals? doent leak water. also engines pull hard to 6700 rpms, but only 45 mph? how fast app should this boat run? thatnks for any help.
