Good Evening Everyone,
I am a long time follower but never posted before. I bought a 1996 Speedster about 2 years ago with a bad motor. I rebuilt the top end and get her running again. This past fall I was going to winterize the engines and found the rebuilt engine was filled with oil apparently from a bad seal from reading some past posts on here. I have a few questions regarding the next best steps.
1. I will most likely rebuild the top end again after I clean out all the oil and just get a hose clamp for when I store it.
2. If I did want a rebuild would it be worth it to purchase a spare engine from ebay or craigslist? Or just take the current one out and send it away?
3. After I rebuilt the engine for the first time, my compression readings were only in the 140's. Is this because I have a thin lower gasket or are the rings not getting a good seal?
I've attached photos of the pistons right now to see if someone can tell me if they look ok with the carbon patterns. Please let me know what my best options will be to keep the boat in the water the longest.
