Some people do not replace the vent lines, I replaced all of the lines including the vent lines as this gave me the opportunity to check and clean the check valves and vents plus gave me peace of mind. Replace one line at a time so you do not get them mixed up and where they connect to confused. Make sure you put the check valve and pressure relief valves on the two vents (one inlet under seat and one outlet by pee hole under rub rail) in the right direction. Regular fuel line from any auto parts store will work. There are two different sizes in the 97xp, 1/4" and 5/16". Replace each line with the same size as the original. my '97 xp took 15' of 1/4" and 5' of 5/16". Use all stainless hose clamps to replace the factory clamps.
Take your time and it is not hard. Oh yeah, The secret to getting to the port hole under the seat on the 97 xp is to loosen the two nuts on the pivot bolts. These bolts are the pivot point on each forward swing arm of the seat. Pull them out of the fiberglass hole. The swing arms flex enough to do this. Just be careful not to scratch the fiberglass and not to loose the rubber and stainless washers. The seat can then be raised from the front and pivoted or suspended out of the way. This is much easier than loosening the shock in the rear. You have to get to the portal under the seat to access the fuel baffle where all of the lines attach to the tank. Also remove and clean the fuel selector valve.
Good luck
