Actually there are 3 oil lines. The one with the filter supplies the pump to the oil injection and the one going under the motor should be a vent/return. If the line you see is coming from the bottom of the tank, it really goes to the front of the motor under the carbs, not under the motor. Another line actually goes from the back of the motor to the top of the tank. Basically the oil is supplied to the rotary valve cavity from the oil tank. It just goes in and fills the cavity. It does not circulate. If that oil is used up or seaps into the motor, it just gets kept full with the oil from the tank. The other line is a vent and should go back to the top of the oil tank I think. There should be a separate line from the bottom of the oil tank to the front (carb side) of the motor that is the supply line for the RV. You really don't need to drain out the oil in the bottom of the motor. You can do it, but not sure many people do. You have to use a suction pump to suck out the oil.
"Actually there are 3 oil lines. The one with the filter supplies the pump to the oil injection and the one going under the motor should be a vent/return" Correct, it is in the right place. Thanks for the help Soccerdad! :cheers:
Everything else is correct, there are two oil lines coming from the oil tank, one goes to the oil pump and has an inline filter. The other goes to a fitting under and to the left of the carbs. The other one goes to the top of the tank and it is a vent line and it disappears under the engine somewhere to a fitting under there. I saw it in the manual also, so that is correct.
Today was a nightmare, i finally got to the carbs, and yes there was some goopy stuff on the fittings, and the filters were very dirty, but i didn't see any dirt inside that i could shake a stick at. But the bad part was that it appeared as if the carbs had been rebuild before and the screws were stripped already. I tried to use an impact hoping that the bit would catch a snag and turned it, but no candy, it made it worse. I got the screws out of the other carb and one screw was kind of almost stripped already, but the impact grabbed it and took it out.
Any suggestions as to where i could go from here? I was thinking machine shop? I have a drill press and a good vice, i thought to drill them and then use an extractor bit to pull them out? Can i heat this carb material? I don't think so...looks like magnesium?
So, i am stuck, other than that, everything looks good, all the fuel lines are in, everything back together, but the carbs.
This is how it looks now.
I took the Doo to a car wash after i took the tanks out, it cleaned out really good. Now those carbs...:willy_nilly:
Hey Soccerdad! Thank you very much for the help, yes sir! Thank you! :cheers::thumbsup:
and yes i did change the two small oil pump lines that go to the carbs..
Again... thanks!:cheers:
