makaveli07
Hey everyone!
So last year I bought a 1996 Seadoo Challenger with a single 787. As some of you might already know it had a couple issues that I will not dive into too deep as I’ve another thread with a video explaining the exact issues all you need to know is boat was running but running rough and the water regulator was leaking. Needless to say to address those issues I did the following:
Before storage I did:
- Fuel was put in last year and fuel stabilizer was added.
- Engine was fogged before storage.
- Antifreeze was also put in before storage.
After Storage:
- Replace water regulator with one purchased from Nick at Westside Powersports
- Replaced Fuel Selector with an OEM one from seadoo.
- Replaced Fuel filter assembly including filter with OEM one from seadoo.
- Cleaned the Rave Valves and reinstalled
- Took out carbs cleaned them and cleaned the filters inside the carbs and reinstalled.
- Syphoned old oil out as it was the wrong oil (blue) and put in XPS oil
- Changed spark plugs with NGK BR8ES plugs.
Anyway Boat started fine outside of the water after all these things this season. However today I went to put it into the water and it started for 5 seconds and died and it wouldn’t restart, battery is fully charged and cranks the engine just fine, but it wont start I noticed that after spraying starting fluid into the carbs and holding both the throttle and the choke in the fully open position it would start up but the minute I let off the choke or throttle it will die. I also noticed there is a bit of water thats getting into the boat and engine bay area. But i can’t locate where its coming from and when i shut the engine off the water seems to disappear.
Boat looks flawless after all I have done to it (redid seats, upgraded stereo, gps)
Any help would really be appreciated I would like to get this thing going before summer is over .
Any help would really be appreciated,
Video added for further clarification
Thank you in advance,
After Storage:
