I bought this boat recently. The po said that he never ran it and it has been sitting for 2 years since he bought it. The last registration sticker was 2017. The motor was full of oil when I got it. I pumped out the oil ran it on some premix to clean everything out. Ran the premix directly into the carbs. Rebuilt the carbs twice. Pto comp. is about 126psi and mag is about 148 psi. I measured the original pop pressure at abouy 15 and 22. After the 2nd rebuild they are both at 30psi. It was a pretty crappy rebuild kit by Venom, but I changed a couple of parts to make sure that those parts were not a problem.
Here is the vid of it running:
Are my crank seals the problem? Something else? What do you think makes it run like that.
