lostatsea13
I picked up a 1996 sea doo gsx  for 250.  Sat for 3yrs after the guy fixing it burnt some wires. Changed the burnt wires got new starter, solenoid, coil, battery, electronic module (without security built in) rectifier, fixed the info center gauge, cleaned all connections I could find, added a master battery disconnect, switched over to premix, So I turn it over checking for spark and looks good and appears to be turning normal, put the plugs back in and it turns a quarter or less stops and the shaft returns where it started, then does the same thing over for as long as the start button is pushed. For some reason it won't go past a quarter turn.  I did notice the starter had nine teeth and original had eight. After checking I was told they both mesh with the flywheel. Having second thoughts about that. Anybody had or seen this before? Maybe got an idea,  I'd listen to anything you got. It;s on the bucket list, so I have to make it out to the fishing spot, Can't do it in a regular boat too dangerous. That's why it's packed with fish nobody wants to fish there. I looked in the books and on the forums but didn't find anything.  thx.
