1996 sea doo spx
wtoll
My 1996 sea doo spx is bogging down at top speed and out of the hole but fine just cruising around. Any idea what it could be or what I could do to fix it. Thanks
Mine just died while running,could the Rectifier be bad here?she will start up again and run than die again
THe rectifier will typically cause a misfire like it is hitting the rev limiter, not kill the engine.
The battery voltage with engine off reads 12.5 volts...with the engine running 5000rpm...the battery voltage reads 12.5 volts.I was thinking the voltage reading should be 14.5 volts?
